How to create a function
Hi
Can anyone help me in creating a function in Labview. This function also contains while loop.
int function(int a, intb)
   while(1)
           int c ;
           c=a+b;
           cout<< a+b;
I need to know the method and how to call this funcion in Labview.
Message 1 of 14
(6,904 Views)
I think you are looking to make a sub-vi with two inputs (inta and intb)
That said, there is nothing telling that function to ever stop. Why do you even have variable C? You don't print or return it.
What are you trying to do?
Message Edited by ctardi on 03-17-2009 07:26 AM
Message 2 of 14
(6,897 Views)
Looks like a homework problem to me.
And if it's not, have you gone through the LabVIEW tutorials?
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
Message Edited by smercurio_fc on 03-17-2009 09:32 AM
Message 3 of 14
(6,890 Views)
I ran across a couple good LabVIEW articles and examples that cover what you need to learn.
One is at:  http://zone.ni.com/devzone/cda/tut/p/id/4161
The other can be found by going to the Code Interface Node help in LabVIEW and opening the provided example.
Those two resources should help you out.
Message 4 of 14
(6,873 Views)
If you want this to be written in G and not C then it is a straightforward while loop wired False to the stop terminal with an addition function inside to add your A and B integer controls together, with an indicator on the outside of the loop labeled C.  Try wiring this up and showing us what you end up with.
Message 5 of 14
(6,867 Views)
I'm not professional on this.  Can touch me by (hyncucn@gmail.com)
Message 6 of 14
(6,834 Views)
I'm sorry, but it's not clear what you're asking. Can you elaborate?
Message 7 of 14
(6,822 Views)
I believe this is what you want:
An infinite/process hogging loop, so be careful with it
 Computer Killer
Message Edited by jmcbee on 03-17-2009 12:30 PM
Message 8 of 14
(6,804 Views)
You are good at that?  I have some intrest in  that.
Message 9 of 14
(6,771 Views)
Hi
I know how to make a sub-VI but I cant make sub-VI including while loop. Infact I am making an application which involves alot of code and I am trying to make the application small by using functions or  subvi. So can anyone guide me how to make a function containing loops (for loop or while).
Message 10 of 14
(6,756 Views)
