How to create a increase until loop?
The raise voltage subvi is to turn on FP-DO-403 momentarily which in turn raise the voltage. The while loop in increase loop is intent to raise the voltage until the voltage reading from FP-AI-110 is equal or greater than the set voltage. My present vi is not doing what I want it to. Anybody has any ideas. Thank you
(2,872 Views)
Set the Required Volatge
Set the Incremental Step Size
Run the VI
"The VI Stops when it reaches the Set Voltage."
labview@ianfung.net
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,872 Views)
