How to create a shared variable that the data type is a cluster stored in a library
Hi all,
I want to create a shared variable that the data type is a cluster stored in a library belongs to the same project to keep the connection with the type def as the photo below shows.
The picture below show a shared variable that the data type is a Enum stored in library (CommonLLB.lvlib).
Thanks.
(1,885 Views)
Taken from this forum discussion.
You can use a cluster as a shared variable type. First you have to convert your cluster into a custom control by right-clicking on your cluster and select Advanced>>Customize. Then save the cluster as .ctl file. In the shared variable dialog, choose "Custom" for the data type and select your .ctl file.
(1,841 Views)
I know this method but the variable loses the link with the cluster in the library, because the cluster will be saved outside this library.
I'm looking for another method.
(1,823 Views)
