How to create a shortcut menu for the pane
Hi all
Well - I know how to create a shortcut menu for a control, but how is it created for a pane? There is the possibility to add an event case for a shortcut menu linked to a pane (see picture), but how can I create this menu?
Message Edited by becktho on 08-01-2006 11:32 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,286 Views)
I don't know how to create a static run-time shortcut menu, but a dynamical creation should be possible  in the same way as is demonstrated  in the example code "<labview>\examples\general\Run-TimeShortcutMenu.llb\Run-Time Shortcut Menus.vi" for the shortcut menu of a control.
So, does anybody know how to access the menu editor at edit-time to create a static shortcut menu?
(3,276 Views)
ahlers option works, sorry but I can't add images from work!
Just use the shortcut Menu Activation filter event? to create a menu.
Ton
Message Edited by TonP on 08-01-2006 12:56 PM
My LabVIEW Ideas
(3,273 Views)
Well this works, but I'm rather looking for the static way. Maybe I did not write clear enough what I wanted to know.
Using LV8.0
(3,263 Views)
