How to create a subvi that outputs a array when the inputs to the subvi are the start, stop and number-of-elements?
Dear readers,
I have been trying to write a sub-vi that outputs an array of numbers. The inputs to the sub-vi are simply the starting number, the stopping number and the total number of elements to be created between the starting and stopping numbers.
For example, if I choose the starting number to be 0, the stopping number to be 10, and the number of elements to be generated to be 11, then the output array should have the values 0,1,2 ... 9,10.
So far, I can make a normal vi with a for-loop (or even while-loop) that does what I want, but I'd like to have a sub-vi that I can re-use to make things more convenient.
Unfortunately, I trie
d to convert the lab-view vi to a subvi, but I get those problems with 'you have a front panel control/indicator in the subvi', and things like that. Also, when I try to pass the start, stop, and number-of-elements values into the subvi, the arrays contained within loops in the sub-vi never register anything. They don't get any values as they normally do in the normal vi.
I've included my little 'normal' vi file that does the function I need. Now I'm trying to have a re-usable subvi that does the same thing.
Could someone please give me some advice to point me in the right direction? Thanks very much for any help in advance.
Kenny
(3,141 Views)
Not to ask a dumb question, but have you tried simply using the "Ramp Pattern" VI (Functions-->Analyze-->Signal Processing-->Signal Generation)?
-Saverio
(3,141 Views)
Check out the tutorial on subvi's. In Help, search for "connector panes". It describes how to assign indicators and controls as inputs and outputs so that your vi can be called as a subvi. Also see Chapters 2 and 7 of the user manual.
As Saverio mentioned, there is an integral function that should do what you need - ramp pattern.vi (not available in the base package).
(3,141 Views)
That wasn't a dumb question at all. That's exactly what I was trying to make as a subvi. Thanks a lot for pointing that function out and for the reply. Much appreciated!
(3,141 Views)
Thanks very much for giving the useful types on connector panes. That should be what I need to get my subvi's to go. Thanks a lot.
Kenny
(3,141 Views)
