How to create a trigger using 9211 modules with cDAQ-9174?
I am trying to create posttriggered acquisition with an analog trigger using 9211 modules that are reading 4 thermocouples.  I would like the data aquisition to start once a temperature of 90 degrees C is reached. I am not sure what I should put for the source of my trigger in my VI.  Are these modules capable of using triggers, and if so, how do I go about creating one?  Attached is the VI, thanks.
(2,796 Views)
The 9211 doesn't have any analog triggering capabilities.  You'll have to implement the trigger in SW (like this example).
Best Regards,
John Passiak
(2,772 Views)
