How to create a truth table based on boolean functions
Third time is charm?
That was weird.  Attachment didn't load properly on two previous attempts and I couldn't edit them either.
Message 11 of 13
(1,072 Views)
Wayne
very much appreciated.
but if i am trying to feed an external value, lets say a numeric constant, to 1 of the 8 numeric controls in cluster of 8 elements.
 What function to use in order to specify that the value of the numeric constant is going to feed into 4th numeric control in cluster of elements i.e what ever the numeric constant value is, it should appear in 110 numeric control.
For that it may also require to change the numeric control to numeric indicator or make a local variable which is not available in this case.
Message 12 of 13
(1,049 Views)
Suggest you read up on clusters and how to modify them.
Message 13 of 13
(1,037 Views)
