How to create an event based timer
I'm using LabView 7.1 and in my application I need a timer/clock which will do the following things depending on imputs
1. When I pass 1 as an input, the timer should not increament and stay in its previous position.
2. When I pass 2 as an input, the timer should start increamenting from the previous value
3. When I pass 3 the timer should clear itself and come back to 0.
I don't need much accuracy and just resolution of seconds will suffice.
Can anyone help me out as I'm new to the LabView
Looking forward for the help
(4,001 Views)
You should use a Case Structure (equivalent of Switch Case in C) & pass the desired values (0,1,2) to it. So, there ll be 3 seperate cases in the CS for 0,1 & 2.
Perform each logic inside each of those cases as per your need.
Also, you need to put this CS inside a while loop & use Shift Regusters (SR) to keep track of the old value.
Message Edited by parthabe on 08-03-2009 05:32 AM
- Partha ( CLD until Oct 2027 🙂 )
(3,996 Views)
Correct...I had thought of this scheme but I'm struggling with time operations...Don't know how to perform it...Could you please explain in detail...
(3,992 Views)
Sorry, I dont have LV installed in my PC.
(3,980 Views)
Jim
(3,959 Views)
