How to create an installation CD using LV 8.0?
How to create an installation CD using LV 8.0? I want to create an Installation CD so I can install the LV application to an user computer.
Thanks a lot
(2,526 Views)
You would need to build the application first.
Then build an installer from that executable, don't forget to incude all required run-time engine in the installer package.
Then burn the installer package to CD, if the package is larger than one CD, enable media spanning (if available in 8.0, it is in 8.2) and select the media size.
André (CLA, CLED)
(2,520 Views)
