How to create/delete a class from CLF file in Labview?
Hello guys! How to create/delete a class from CLF file in Labview?
I exported a script from NiVision Assistant to the Labview and I want to know how to  create/delete a class from CLF file in Labview?
(1,877 Views)
As a first step, explain the problem in much more detail and define all acronyms.
If your problem focuses on vision, there is also a dedicated forum.
(1,841 Views)
Why don't you post your code (preferably in LabVIEW 2019 or 2021 -- Save for Previous Version if necessary)?  Give us a hint what to look for, or where to look ...
Bob Schor
(1,813 Views)
I made a script in Ni Vision Assistant using the color classification function, where I created different classes and samples for different types of food.
Then I exported the script in Labview.
I want to be able to create/delete classes from Labview. How can I made this VI?
(1,764 Views)
Thanks for attaching the VI.  I now know that a CLF file is a "Classifier" file in IMAQ, related to the Machine Vision VIs (and, more specifically, the Machine Learning VIs) that are part of IMAQ.  This is way over my head and range of experience.
My recommendation is to look on the Web for topics and tutorials on LabVIEW Machine Learning and LabVIEW Machine Vision.  You might also search this Forum.
Bob Schor
(1,739 Views)
