How to create error terminals on an ADD- node
Hi community,
when I was just browsing through the example finder, I found in the "...LabVIEW 8.2\examples\Time Series Analysis\TSAGettingStarted.llb\Correlation Analysis.vi" this node. It seems quite usable, but how was this done?
greets, Dave
Message Edited by daveTW on 07-17-2007 04:01 PM
Greets, Dave
(2,943 Views)
That happens automatically when the inputs (both of them) are of the "waveform" datatype.
Message Edited by smercurio_fc on 07-17-2007 09:33 AM
(2,928 Views)
It's not really for dataflow and it's useable with waveform data only because there are conditions that can cause an error. For example, if you attempt to do a add of waveforms with a different dt, you get an error.
(2,921 Views)
Aha, great, thanks
Greets, Dave
(2,914 Views)
