How to create file names automatically?
The attached program is supposed to create specified number of files. Later on, I will save CCD images (1024 X 1024 pixels) in those files.
This program is giving me error and if I choose to ignore the error, I have to click "ok" for each new file name (which is unwanted).
Dushyant
(4,022 Views)
Salutations,
It was in your naming and path convention.. I've modified your VI and it seems to work. If you have further questions, don't hesitate.
Sincerely,
ElSmitho
(4,014 Views)
You don't have a default name defined, you're appending a carriage return, and you wired the name to the wrong place. The default name is not the path.
(4,008 Views)
Thanks guys.
I really appreciate for your help.
Dushyant
(3,973 Views)
Thanks a lot for responding to this thread and helping me out.
Dushyant
(3,972 Views)
Dushyant
(3,971 Views)
Hi!
See the attached example, where i have generated file name with Date and time stamp.
Instead of date and time you can give other names also.
Kaustubh
VC (Pune)
INDIA
(3,956 Views)
