How to create/get ColorPal driver for LabVIEW ?
Good morning !
I'm a french student in internship in England and I work on the Starter Kit 2.0 (with DaNI Robot). My company would like to transform the obstacle avoidance feature (thanks to the ultrasonic sensor) in a colored line follower (thanks to the ColorPal from Parallax). Thus I want to program in LabVIEW but I don't really know how to get the necessary ColorPal driver or the VIs to communicate between the sbRIO 9632 and this color sensor. I use the same wire as the ultrasonic sensor to plug the ColorPal.
Thank you in advance for your help.
Regards
Kevin
(4,234 Views)
Accepted by topic author kak40
Hi Kevin,
I have taken a look at the documentation for the ColorPal and it seems it is programmed using serial i/o. As you can see below:
What you will need to do is use LabVIEW's VISA and Serial functions found under the instrument i/o palette to communicate with your ColorPal. I recommend downloading the ColorPal documentation from their website and study the syntax of the commands you will need.
Also for reference here is a good place to get started when programming VISA.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(4,159 Views)
Hi
I'm looking at doing the same thing.
Did you manage to get it working?
Regards
(3,951 Views)
