How to create installer that copy files only if they are newer
I have an application with a couple of configuration files that are modified for each machine they are installed on. How do I build an installer with the LabVIEW 8.0 application builder that only overwrites these files if they are newer than those currently on the system?
(3,954 Views)
Ksmith,
Unfortunately the installer will not be able to overwrite files without user interaction. Basically this is how it works. When you create an installer it is actually a MSI file that will run with a product code. The installer checks the code vs any other codes and if the code already exists, it will prompt to un-install. If you have different product codes for the same exe but different versions, I am not 100% sure it will allow you to install in the files in the same place, however, if it does when the installer tries to overwrite a file, Windows is smart enough to ask if you want to replace. If you select yes to all it won't check versions. However, you can go through files one at a time and choose. This is a limitation of using the MSI installer, however it is the best installer for windows based applications. Let me know what you come up with.
Tyler H.
(3,943 Views)
Hi Tyler
Just today I reinstalled an application but there was neither a "do you want to uninstall the previous installation" nor a "do you want to overwrite file x".
All existing config-files (like *.dsn, *.xml, ...) were overwritten.
Last week I also reinstalled this application without checking for overwritten files - this caused the program to write data into the wrong database.
Is there really no way to change this behaviour? Because if I make a SW improvement, let's say something like a bugfix, I just want to reinstall the exe but keep all the other files. Now I can't do this - I have to copy all the settings to a different folder and copy them back after the reinstall.
If msi is the best installer for windows, well that's another topic, but for my other applications I use Inno Setup (http://www.jrsoftware.org/isinfo.php) since a few months. There I can specify how the installer should handle already existing files.
I wished such a feature was available in the LV installer.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,844 Views)
My work around for this situation was to create two installers, one for clean installations and one for updates.
(3,842 Views)
Well - that's not really comfortable, if you have to maintain several build specifications.
Can we expect an improvement regarding this topic in a future LV version?
Using LV8.0
(3,839 Views)
