How to create installer with python connectivity to be installed on computer without labview?
Hello. I am currently developing an application with LabView 2020 which has a built in python integration.
My application works well but I had a problem when creating an installer for the program, because I would like to install the program to another computer without LabView.
Normally I had no problem with creating an installer (when no ad-on is used), however, since I am using the python integration, in my opinion it may required different treatments.
I understand that the python integration is still on the development stage by NI, so my question is, is it possible to do at this moment?
Thank you very much.
(1,762 Views)
Accepted by flim21
Hi Edobp,
I believe that your concern is that wether you need to include Phyton in the installer of the program as an add-on.
After building your exe. file, you can run it on another computer without Labview,as long as you have the LabVIEW Run Time installed.
However, as a reference for you to install a third party installer such as Phyton, you can refer to the following attached KnowledgeBase link below.
Including Third Party Installers and Drivers in a LabView Installer
Fiona, NI
(1,699 Views)
