How to create link in labview
Hello Friends
         I m Using labview,How to create the hyperlink in labview for example:
Forgot ur password
Like this how to create in labview what type of action will be use
Jai
Jayavel
(4,302 Views)
Hi Jai,
you can use a "normal" button. Change the boolean text, make the string underlined and create an value change event in the event structure. In the event you can decide what you want to do if someone press the button. You can for example use the "Open URL in Default Browser" to open a webpage.
Mike
(4,289 Views)
What is it that you are trying to do exactly in your application?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,262 Views)
Hi Jai ,
   IF you can dicuss your application then it will more easy and directed for all of us to give you suggestions?
Did the first reply helped you?
Pranchal
(4,211 Views)
Is it possible to do this without an event structure (so that it will also work in Labview basic?)
I'm not sure whether this is what the original question intended, but I would like to to have the text underline on mouseover to simulate the effect of a browser text link and then handle the click with a case structure (like in the lists on the Labview Getting Started window that appears when you don't have any VIs open)
(4,128 Views)
