How to create logging file with timer
I am new to Labview. What I am trying to do here is to create a log file with the data acquire from an instrument and a GPS, the logging of the file can by set by a timer (eg 500ms).
The instrument will return to me the Signal strength level, BER and more. Hence I need to create a log file to record the data from the two instrument, however I am totally lost on how I could get this done, I have look through some of the example given but was not really what I need.
Any  example or suggestion would be greatly appreciate.
Thank
Lawn
(3,043 Views)
Hi Lawn,
I have attached a picture below on how you can create a timer for logging. Is this a good start for you??
Regards
Lee
NI ASEAN | Applications Engineer
(3,013 Views)
