06-20-2006 09:48 AM
06-20-2006 11:35 AM
You can raise custom events to be handled by the event structure. Have a look at the shipped example Dynamically Register For Events.
David
06-20-2006 12:09 PM
06-21-2006 01:28 AM
Hi Severin
Had you searched for Application Design Patterns on the ni site. One of the links is this http://zone.ni.com/devzone/learningcenter.nsf/webmain/338EE44CB1C3450986256C2B007CF8C5. There are other links that come up on the search that are worth browsing.
In the beginning I found this a great way to learn how to choose a design template which would be the most appropriate for my application. Labview provides these as templates if you got File then New ... you find them there. And there are examples.
In my opinion you should look at a State Machine for your application.
There are a number of ways to keep track of your variables such as using shift-registers, indicator propery nodes, LV2 Globals etc. Keep thinking data flow and always keep an eye on race conditions.
Hope this helps
David
