How to create table from .ini file
The file *.ini generates a Multicolumn Listbox where is indicated a number (variable) of tables with them characteristics (row and column) as in the picture below.
I need to find the way to create automatically, on word file, the tables as indicated in the *.ini file. Do you think that it could be possible? That you know, exist a Macro to do this?
Best regards
Message 1 of 8
(5,225 Views)
This actually sounds like a question on how to program a Word macro.  As opposed to trying to create LabVIEW code.  You should probably ask this question in an MS Word forum.
Message 2 of 8
(5,215 Views)
I would like to use the Labview code.
Message 3 of 8
(5,196 Views)
Sounds like you want to use the Report Generation Toolkit.
Message 4 of 8
(5,182 Views)
But you asked about using a macro.  Word has macros.  LabVIEW does not.
Message 5 of 8
(5,158 Views)
I need to find a way to create a table automatically in word file, but i am not able to (i don't know how to figure it out). Could you kindly give me some suggestions to find a way?
Message 6 of 8
(5,112 Views)
As Taki said above, to do this you need to use the Report Generation Toolkit. This will allow you to generate tables in a word document. Look for the examples in the LabVIEW Help for a rough idea of how to use the toolkit and if you have any specific questions after that then feel free to post them here.
(blog)
Message 7 of 8
(5,101 Views)
There's this - https://decibel.ni.com/content/docs/DOC-24118
Jim
Message 8 of 8
(5,091 Views)
