How to create this control
I have a project which contains a control which I cant figure out how to create. I have attached it here. If we click inside the control, it shows the menu with four elements each with a different color and a name.
Kind Regards
Austin
(2,845 Views)
Hi Austin,
it's a picture ring...
(Btw. the context help already tells you it's a ring! In the properties you will find hints for using pictures as the ring objects.)
(2,841 Views)
Hello Austin,
Creating this kind of control is called cutomizing a control in LabVIEW. To create a custom control, place the standard control on your front panel, Right click the control, Click Advanced and then click customize. Follow this link for more details .
NitzZ
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved;))
(2,834 Views)
