07-10-2015 01:46 AM
Hi GerdW,
I have just editted my previous message, but you have not seen it I think.
Unchecking the waveform graph "ignore time stamp" option corrects it (see below). At least it is seen. Actually the vi works without problem but I was not able to see it on the graph due to ignoring of time stamps. Am I right?
07-10-2015 01:53 AM
07-10-2015 02:58 AM
Doesn't it mean if I use these vi to generate AO, it generates them sequentially? Is it a virtual result only?
07-10-2015 03:03 AM
Hi Egemen,
when you setup a DAQmx task with two AO channels and supply a waveform for each channel I guess both channels will be started at the same time.
On the other hand you probably need to have both AO channels in just one task, depending on your DAQ hardware…
07-10-2015 03:18 AM - edited 07-10-2015 03:19 AM
Hi GerdW,
I am planning to use that vi only to create a time delay between two waveforms and generate a AO signals in one task. I modified an example vi to generate finite output AO with a delay on the second signal. Do I think in the wrong way?
By the way, I am planning to do it with NI USB-X 6353 or 6343.
