How to crop video using ROI
Would some one please help me?
I have a loop which continuously aquire images from a camera and saves it to a video . I would like to crop a region of this video by passing the co-ordinates of a rectangle.After I have the cropped video, I would like to do a intensity profile of the whole video and display it using a single graph ( intesnity changes for diffferent frames in the y axis and the the number of the frame in x - axis.
Joyce Joy
(3,634 Views)
I think you will have to crop each frame individually. Use the IMAQ extract VI (http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_extract/)
Depending on the frame rate of your video capture, will determine if you can do this live or offline.
(I usually work with still images, and not continuous video)
(3,616 Views)
Did you get the answer to your question..I want to do the same thing...please send me the program if you got the solution
(3,399 Views)
You can implement image cropping following the example:
https://decibel.ni.com/content/docs/DOC-11222
You would have to programmatically generate the ROI rectangle if you do not wish to have user interaction in the code.
I am not quite sure what kind of intensity profile you want, but here is a good example that performs it along a line, so you could just build an array of those and plot it.
https://decibel.ni.com/content/docs/DOC-20840
Hope this helps!
National Instruments UK & Ireland
(3,372 Views)
