How to cusotmize a control to cover other controls?
Sorry for not reading the question correctly.
LabVIEW sometimes seems to mess up some coordinates. I think
the result is always there, but only noticable in arrays. You can see
strange selection "ants" (the animated selection square). When moving the
control (not in an array), the selection rectangle sometimes changes size.
The size of the selection rectangle is also different when customizing the
control.
If you eddit a comtrol carefully, it doesn't happen. I'm not sure when it
happens (what you shouldn't do), but in most cases it seems to work fine,
like the attached control (also works inside an array).
Wiebe.
"isharryf" wrote in message
news:506500000005000000A79C0100-1079395200000@exchange.ni.com...
> Than
ks for your answer.
> I do know now that only data can be changed per element. I tried using
> this by using one boolean in the cluster to cover/hide others
> controls. As you might have seen in my seconde example this works fine
> within a cluster, but why not in an array. As you described, I can
> change the value of the boolean seperately. And eacht booleans has two
> graphical presentation (depeding on state). Why does this not work in
> this array? More interesting, why does a boolean with indepent size
> betwee on/off in the customizes window behave different from the
> presentation of that control back in the VI?
[Attachment test.ctl, see below]
Message 11 of 12
(513 Views)
Thanks a lot. So it does seems to work.
Message 12 of 12
(513 Views)
