How to cut waveform
I have a waveform which is repeatting itself(out of DAC). I have added zeros at the beginning and end of the waveform as shown bellow. How can I cut only one copy of waveform. I have attached csv file of the waveform.
Here is what I have tried but every time I have to do it mannually and it is not accurate.
(3,062 Views)
Hi shirin,
what's the point in multiplying with zero and one?
Why don't you search for your "added zeros" in the signal?
Suggestion:
(3,055 Views)
Hi GerdW,
-Just to compare original and selected size of data(It will not effect the cutting process anyway)
(3,046 Views)
Hi shirin,
@shirin91 wrote:
I have to add zeros before DAC so after DAC it will not be zero exactly, so I can not just seach for it.
But there seems to be a clear distinction between "signal" and "gap": you just need to define this distinction and then create an algorithm to detect it in your waveform!
How do you define the "gaps"?
(3,042 Views)
My guess is that 0 is an absolutely valid value for a datapoint.  That makes it harder to trigger.   Options:
  • Change your "fake zeros" to NaN.  That does require a change at the recording end but is soooooo much simpler.
  • Envolope detection.  Absolute Value, clipping(use In Range and Coerce with a smallish positive value,) and a low pass FIR filter is the most common means.  Play with it to see how your data behaves with both GOOD and BAD data
  • Assume Something.  What do you know about the waveform? Is the Duration fixed?
Good hunting!
(3,022 Views)
