How to deal with way oversized front panels?
@kbbersch wrote:
I like the Ctrl-/ answer the best.  I learned a lot of Windows shortcuts I didn't know.
Except this is not a Windows shortcut, but a (even more oscure) LabVIEW shortcut. 😄
(maybe I am wrong, but it does not seem to work in other programs I tried)
Message 11 of 30
(1,550 Views)
Just toggles the status bar in Firefox.  Must be a LabVIEW shortcut I didn't know about.  I'm sure there are lots of them.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 12 of 30
(1,543 Views)
Ctrl-t is not only mnemonic (tile), but afterwards you get access to the resize corner of the window.  Maximizing leaves you stuck at full-screen, and that is almost as annoying as super-sized.
And I would avoid cascading windows at all costs, an even bigger disaster than tiling, and not undoable.
Message 13 of 30
(1,530 Views)
I know (and hate) ctrl-t very well, because I am often faster than quickdrop.
(ctrl-space...ctrl-t does an unintentional tiling if the quickdrop window comes up too slowly... :()
Message 14 of 30
(1,517 Views)
This is supposed to be a non-issue... if only the Edit mode size is decoupled from the Run mode size 🙂
Message 15 of 30
(1,503 Views)
True, but once you have it maximized you can grab and drag the title bar to allow you to resize the window.  I don't like keeping VI windows maximized, but this is a good workaround for cases where you have a VI like the one referenced in this thread.
Message 16 of 30
(1,458 Views)
@altenbach wrote:
Darin.K wrote:
I feel dirty now, time to shower.
Yes, there are ways, but try to even get to a browser window to look up these shortcuts (well, alt-tab works, but again we need to remember at least one of these key combinations).
My favorite is alt-F4, of course 😄
This is like the browser exploits from the early internet era and should not happen in 2014.
Try Ctrl+H while hovering over any objectSmiley Wink  seach the keyword "Keyboard Shortcuts"  The main LabVIEW Help lists the shortcuts as a table and even links to
C:\Program Files (x86)\National Instruments\LabVIEW 2013\manuals\ LV_Quick_Reference.pdf  which is in a rather convienient format to print and hang on your wall.  If wallspace is a premium- contact your local rep and get a mousepad.
Of course a quick post to the forums should also geterate some great answers.
As an asside Ctrl+/ is application specific I typically re-map it to Create Snippette from selection since I do that so often and use maximized windows so seldom. It prevents accidental triggering of maximize.
Message 17 of 30
(1,431 Views)
Jeff, I actually printed that card yesterday and taped it to the wall. 😄
LabVIEW needs to do some sanity checks on the window parameters before placing a window.
Double-clicking a terminal typically flashes the control and pans the FP if needed. Here I see nothing because it flashes a control that is way outside my screen and all I can do is continue to stare at a completely blank FP.
Message 18 of 30
(1,422 Views)
Message 19 of 30
(1,422 Views)
When I saw Christian asked a question, I expected this to be a thread resurected from 10+ years ago.
Message 20 of 30
(1,407 Views)
