06-14-2009 08:53 AM
In the attched example file (which is a part of my program)I have 3 basic stages, enclosed in a sequence structure:
1) I initialize the GUI buttons
2) I check the instruments in my system are opened and ready to run ("VSWR initialize vi")and issue a true/false result.
3) A case structure for normal run or abort operation (if the instruments do not
respond correctly).
4) If everything is ok the user has to scan a S/N using a bar code scanner.
The problem is that when I run the program the EVENT STRUCTURE in the FALSE part of the case is automatically activated, before the VSWR initialize vi is started!
This causes that when the user tries to scan the serial number on the GUI he can only type one character and then the screen is stuck.
If I disable the result from the VSWR initialize vi (as shown on the example) and connect a TRUE constant to the case structure, the event structure is not activated but then of course I can not use the "VSWR initialize vi".
How can I make sure the event structure is activated only after the two first parts are done? That is, in normal order - only after the "VSWR initialize vi" returns a false result.
Note, there's no need to understand each component in the attached file. The question is rather a general one about the right way to synchronize my program.
Can anyone help ?
Thank you in advance.
06-14-2009
11:43 AM
- last edited on
07-09-2024
04:44 PM
by
Content Cleaner
This can't happen because of dataflow. I don't know what your Initialize is doing since you did not include it.
General comment: you should restructure your code. You should look into using a state machine construction, or better yet, a producer-consumer architecture. You will be far better off.
Also, code like this:
and
is simply silly. Comparing a Boolean to True is redundant.
06-14-2009 01:48 PM - edited 06-14-2009 01:49 PM
Saverio already mentione most critical points. here are a few more:
A very ugly quick fix (duct tape repair) is to configure the events to NOT lock the FP until the event completes. I recommend against this.
Of course the entire code should be rewritten in a similar fashion and around this single event structure. A second event case could deal with the error condition. Simplify!!!!
06-14-2009 02:19 PM
The output of "empty string?" in the image above should be inverted, of course.
This is just a draft and there are probably other errors, I did not test. Modify as needed. 😉
06-15-2009 03:03 AM
Thanks!
Theses are really some useful tips and links.
I think I have some homework to do....
