03-18-2016 06:27 AM
Hello every one,
(As I mentione before, I am very beginner to labview environment 🙂 )
A function I am trying to call from imported DLL, passes an adress of struct type variable. The strcut variable is defined with in header file of the DLL file. Do I need to declare the struct variable to pass its address while calling the fuction from labview ? if yes, would you explain how to declare and initialize a varibale using the same struct name(the same struct name with in the headere file) ? e.g CIFX_PACKET tSendPkt = { 0 }; ,
CIFX_PACKET tRecvPkt = { 0 };...... 'CIFX_PACKET' is struct data type defined with in DLL header file.
Thank you very much for your help in advance
03-18-2016 01:13 PM
You have two options:
1) Create a cluster in LabVIEW that matches the memory layout of the C struct. Wire the cluster constant to the Call Library Function Node, with the type set to "Adapt to Type." LabVIEW will automatically pass a cluster as a pointer to the cluster.
2) Create an array of bytes (using Initialize Array) of the same size as the struct, and configure the Call Library Function Node to pass the array by pointer. Write LabVIEW code to reintrepret that array as the desired data.
If your struct contains pointers, it gets more complicated. Post your struct definition if you want more specific help. The LabVIEW Help topic on "How LabVIEW Stores Data in Memory" is useful for getting the cluster/struct details right. You also need to be aware of how elements of the struct are aligned; you may need to add extra elements in the LabVIEW cluster for padding.
