How to delete columns from a array
Hello
I have an 2D array that consists of 12 columns. I just want to use the first three columns inside LabView. What is the quickest way of extracting the data from these three columns?
Greetings
Kristoffer
Message 1 of 8
(5,366 Views)
Accepted by topic author Sjefsgjogleren
You can look at it from two different angles:
  • You can delete the extra columns
  • you can keep only the fist three columns
Easiest would be to use "array subset" and select the first three columns. See picture.
(This assumes that you want the three columns as a 2D array. If you want them as three 1D arrays, you would use "index array" resized to three outputs.)
Message 2 of 8
(5,364 Views)
array subset then process the data? I believe that will return 3 columns from a 2d array check the context help
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 3 of 8
(5,361 Views)
Thank you, this seems to be the way of doing it. May I just ask how i can define the columns instead of the rows?Smiley Embarassed
Message 4 of 8
(5,347 Views)
Please define what you mean by "extracting data from columns". This can be interpreted in many different ways  (The above solutions extraced the first three columns, possibly not quite the same).
You could for example transpose the array and autoindex at a FOR loop with a "3" wired to N and it will process the first three columns, one per iteration.
Please clarify what you need to do, exactly. 😉
Message 5 of 8
(5,346 Views)
Look at my picture above. Wire the number of columns to the lowest "size" input and leave the rest of the lower inputs of "array subset" unwired.
Message 6 of 8
(5,342 Views)
It depends where you are giving the length value. 1st index and length corresponds to row and the 2nd index and length corresponds to coloumn.
Good luck
Message 7 of 8
(5,337 Views)
I mean just the way you showed in the picture above;) I got it all right now, thanks a lot for the help!:)
Greetings
Kristoffer
Message 8 of 8
(5,337 Views)
