How to deny access to a configuration file
The Deny Access function returns an error 1 when wiring the refnum from a configuration file. The LV help only mentions that you cannot deny access to a datalog file. Am I missing something obvious ?
Message Edité par JB le 02-26-2009 06:20 PM
(2,848 Views)
JB,
Try closing the file first.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,841 Views)
Configuration file references are created and tracked by the Config Data Registry VI (in C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\Utility\config.llb).  You'll notice that the confuration file reference number (e.g. 2) doens't match the file reference number ( e.g. 445644800).  This is why the "To More Generic Class" node doesn't accept the Configuration File Reference Constant.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(2,834 Views)
