How to deploy MySQL Workbench into installer
I have a customer to whom I want to deploy a LabVIEW exe and MySQL Workbench (so that they can view their results).  I would like to have both in the same installer.
I recently did something similar by adding an exe to the end of the installer, however, it is not possible to include a .msi file as part of a deployment installer.
I thought of putting together a batch file but when MySQL Workbench is included in the installer, it gets split up and it is no longer obvious how to launch it.  Is their a way to include a .msi program as part of a deployment installer and then launch it during the install?
Seán
(3,634 Views)
Hi SeanJ,
You can include 3rd party installers in the LabVIEW installer following the next steps. For .msi installers, you will have to create a batch file first in order to run the .msi installer.
Add the executable (.exe, .bat) for the installer into the LabVIEW project by right-clicking in My Computer. I suggest adding the whole folder containing the installer just to make sure you included all the required files for setup.
When you build the application, add these files into the "Always Included" section in the Source Files category.
When you build the installer, the files should be included when you add the application in the Source Files page.
In the Advanced tab in the installer, click on the "Run executable at end of installation" box and select the 3rd party installer from the Source Files options.
Please a take a look at these articles for information on how to set a batch file and running executables after installation.
Creating a Batch File
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LZOSA2&l=en-US
How Do I Make My LabVIEW-Built Installer Run an Executable After Installation?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIDkCAO&l=en-US
Running a Batch File Automatically After an Installation to Access Installer Files
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OBeSAM&l=en-US
Please let me know if you have further questions.
Kind regards,
Robert P-F
(3,582 Views)
