How to detect USB Flash Drive name in LabVIEW
Hi there
I was looking for how to detect a USB Flash Drive name in Labview
appearently every time i insert USB Flash Drive in a computer, windows assign it a different name
once "J:" and sometimes "M:"
Is there anyway to obtain USB Flash Drive name programmatically in Labview ?
Because in my program an user shouldn't be able to access HDD Drives except his USB Flash Drive (for inserting some file ...)
thank you and excuse me for my poor english
Message 1 of 8
(10,084 Views)
This question has been asked before several times. Did you try a search? http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3A170&q=detect+...
Try the solutions/suggestions already posted. If they don't work then you can come back and indicate why they are not adequate.
Message 2 of 8
(10,078 Views)
Thank you about the link but they don't work
I still have the problem
Is there any Windows API based solution?
or anything else ?
Message 3 of 8
(10,054 Views)
What is wronge with these VIs ?
http://webspace.webring.com/people/og/gtoolbox/dl/DeviceMonitor.zip
I can not load it in LV2010. Why ?
I think this VI could be solution of my problem
Please help
Message 4 of 8
(10,040 Views)
I was able to get the demo.vi to load, but it could not load the other two because there is no block diagram associated with those.  I'm not sure why this is.  I haven't had any issues with other llbs before.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 5 of 8
(10,024 Views)
I just came across the same error message from a different thread that explains it.
http://forums.ni.com/t5/LabVIEW/G-Toolbox-for-LabVIEW-8-6/td-p/840513/page/2
Message 6 of 8
(10,019 Views)
Finally found the solution
By looking at MSDN. There is a function named "GetDriveTypeA" in Kernel32
Here is the program. It finds USB Flash Drive letter or else leaves it empty
Message 7 of 8
(9,974 Views)
Here is a LLB that does more.
Tim
GHSP
Message 8 of 8
(9,968 Views)
