How to detect a sponge ball passing by in a transparent Acrylic pipe?
I would like to use a camera or sensor to detect the existence of sponge balls passing by in a transparent acrylic pipe. The ball size is in the range of 12mm to 17mm and the speed of ball can be up to 1m/sec. Suggestion of what kind of camera or sensor and NI hardware are suitable is very much appreciated.
(2,733 Views)
Check with "Keyence". They may have something that will work, but brace yourself, challenges cost $$$.
Another quick thought;
Did you concider listening for them? If you put a speaker generatin a steady tone on one side of the pipe and you press your ear up against the other, can you here the difference when the spounge ball passes?
Ben
(2,733 Views)
Have you thought using a light beam passing trough the pipe and detected at the other end by a photo detector. I think you would be able to easily detect when the ball is "cutting" that beam.
(2,733 Views)
If you're willing to design and build some hardware, how about a cheap photo-sensor (photo-diode or photo-transistor) and a simple light source? You can find sensors from Fairchild, Honeywell, Omron, Optek, and probably a bunch of others.
A lot of these sensors act basically as a switch: they conduct when they see light. Connect one side of the sensor to a pull-up and the other side to ground and check the output at the junction of the pull-up and the sensor. You'll get an inverted output: when it sees the light, the 'switch' is on and the output is low; when the ball blocks the light, the switch is off and the output is high (pulled up).
(2,733 Views)
