How to detect mouse click event?
I would like to have a vi to detect left, right and no mouse click. I mean that in the vi attached, Button2 should be 0 (no click), 1 (left c.) or 2 (right c.) depending on the event occured in i-1. cycle. My vi is the modyfied version of the one found here:
http://www.ni.com/example/27663/en/
Sometimes it works fine, but another time nothing happens when I click.
I think the main problem is with the execution times at the for loop and event structure.
Could you help me how to deal with the problem?
Thanks you!
(3,658 Views)
Hi VampireEmpire,
Your For loop iterates twice. If an event occures during first iteration everything is fine - Button 2 refreshes during second iteration. But what happens when an event occures during second iteration? Does Button 2 have a possibility to refresh?
1. Do you see the problem now?
2. And if you do - do you really need For loop? I would suggest you trying removing it and connecting shift register to the while loop.
Bluesheep
(3,639 Views)
Hi Bluesheep!
Thank you for your fast reply! Now it works fine.
(3,629 Views)
