How to detect the installed device name
I am using Labview 8.5.
I need to display the device name installed in my pc.
I have a PXI chassis with DAQ,Digitizer and function generator card.To display the DAQ device name used the "DevName" property of DAQmx driver.Similarly to display the Digitizer and function generator card name which function do we need to use.
Please tell me how to do this?
Regards
Meenatchi
(3,857 Views)
Please see the attached zip of VIs.
- Partha ( CLD until Oct 2027 🙂 )
(3,831 Views)
In NI-PXI IDs.vi, you need to give the No of Devices as 2, to make the For loop run twice, one each for DSO & DMM.
(3,828 Views)
Hi  Meenachi,
I hope your query is solved. The code parthabe posted seems self sufficient.
regards,
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,805 Views)
Hi Vaibhav,
Just an offline que...
Are Meenatchi & you working in the same company?
Maybe can you mail me to my personal ID parthabe@rediffmail.com to discuss further?
(3,800 Views)
No partha, i don't know him/her.
Vaibhav
...//____//......
..//____//......
.//____//......
(3,781 Views)
