How to detect when a tabbed page has focus?
Is there a way to set a bool flag when a user selects a tabbed page on
the main screen?
i.e. how can the program detect at runtime which tabbed page is active?
this is for LV7.1
tia
(2,888 Views)
Just read the control. You can right click on the tab control and select Create Constant and use that as a comparison or since an enum also has a numeric value, compare the control to a U32. The value of the first page is 0, second page is 1, etc. You can also wire the tab control directly to a case statement
(2,881 Views)
On the block diagram The Tab Control will output what page has been selected. Just wire this to a case structure. See attached vi in LV7.1
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,879 Views)
Sorry there were no replies when I started, got distracted..
Andrew Alford
(2,877 Views)
thanks! works great!
(2,859 Views)
