How to determine specific row in table clicked on
Hello -
I need to determine the specific row of a table control that is right-mouse-clicked on.  I think this is only possible by using the Shortcut Menu Activation? event for the table control and obtaining the vertical coordinate in the Coords filter options.
This entails performing experiments to determine the vertical range of each row in the table, or perhaps by determining the width of one row and using a linear relationship to determine the possible range of subsequent rows.  Do you feel this is the best strategy or is there possibly another easier way to obtain this information?
Don
(3,987 Views)
Pop up on the Table and CREATE INVOKE NODE for POINT TO ROW COLUMN.
Place that node on your diagram.
Feed the COORDS cluster to that node, and out comes the row and column you clicked on.
Be careful of edge cases, I don't remnember exactly, but if you have scroll bars visible, you might have to take them into account.  Use the IN BOUNDS output
Steve Bird
Culverson.com
LinkedIn
(3,983 Views)
Accepted by topic author DonRoth
You can use the CtlRef with the Table Point to Row method to get the information.
Ben64
I was too slow to answer ...
(3,979 Views)
Awesome.  Thanks to you both.  I should have checked for invoke node methods.  I for some reason got stuck on filter events.
Don
(3,965 Views)
