How to determine what card is in what slot of a PXIe-1073 unit programmable
How can i programmable determine what card is in what slot of a PXIe-1073 unit I have a PXI-4063 and a PXI-2503 in a 1073 chassis. I use the DAQmx Device Product Type to to find the 2503 matrix card but it woun't return the 4065 product type.
(3,051 Views)
Hi cjp1,
The KnowledgeBase article Programmtic PXI Slot Detection walks you through the steps to do this. There is also a community example called Read PXI an PXIe Card Serial Numbers Programatically that demonstrates the type of LabVIEW architecture you can use to do it.
You should first ensure that all of your modules can be identified and self-test in MAX.
In case the above hyperlinks don't work, you can copy-paste the addresses below:
http://digital.ni.com/public.nsf/allkb/2342900AED02975A86256BD800764C8B
https://decibel.ni.com/content/docs/DOC-20207
(3,018 Views)
Thanks olr the reply
(3,001 Views)
My pleasure, cjp1.  If that resolved your issue, please mark it as the solution, so other members of the community can easily find it. (Kudos are always appreciated too.)
(2,989 Views)
