How to determine what percentage of a boolean array is true or false?
I'm trying to figure out how to take a boolean array and determine what percentage of that array is true. So far I can only really find the AND Array Elements Function as far as evaluating the array goes, and my Google searches haven't come up with anything helpful. Is there a way to do this on Labview?
(3,063 Views)
Something like this should work.
mcduff
EDIT: Do the summation after the division, otherwise you can have an overflow error.
(3,059 Views)
gonna go ahead and try that. Thank you so much!
(3,050 Views)
Count the number of True elements in the array.
Use that number and the array size to calculate the percentage that is true.
=== Engineer Ambiguously ===
(3,003 Views)
