How to develop the NDIS miniport driver to read OID
I need to develop a NDIS miniport driver to read the OID "OID_GEN_VENDOR_DRIVER_VERSION" from my machine. Is there anyway can do it?
Im using Labview 8.5.1, the port connect to my machine is using USB & LAN cable, actually it is a ethernet snap on adapter.
The window os version im using is xp.
Thanks.
(2,822 Views)
Thanks.
IF I understand correctly what you want to do, you are completely wrong here. You will most likely want to look into using the Windows DDK and using a C compiler.
Rolf Kalbermatter  My Blog
(2,817 Views)
