How to directly communicate with a Rockwell Kinetix 300 Ethernet/IP Servo Drive with LabVIEW using Ethernet/IP protocol
I have a Rockwell Kinetix 300 Ethernet/IP Servo drive and I would like to communicate with it using LabVIEW through Ethernet/IP protocol. I've being using Ethernet/IP protocol on other applications to communicate with ControlLogix CLPs with no problem. But now I would like to communicate with a Kinetix Servo Drive in a way I don't have to use Rockwell PLC to control it.
Also I would like to communicate with a Frequency Inverster Model Power Flex 400 also from Rockwell.
Does anyone have any example or ideas for this communication?
Thanks a regards!
Luciano Borges
Test Development Engineer
(4,522 Views)
Are you using the driver from NI -https://www.ni.com/en-us/shop/product/ni-industrial-communications-for-ethernet-ip.html ?
I believe questions related t to that are handled in the Industrial Communications board.
https://forums.ni.com/t5/Industrial-Communications/bd-p/260
(4,512 Views)
Thanks for the answer Dennis. I will post the message on the correct board.
Yes I'm using this driver.
Thanks.
Regards
Luciano Borges
(4,506 Views)
