How to disable default led event in labview
Did you even read my post above? I said to make it an indicator and use a "mouse down" event on the LED instead of a "value change" event. Did you try?
Why should it be a control? Can you explain?
Message 11 of 14
(601 Views)
Hope this is what you are looking for
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 14
(590 Views)
Hi altenbach,
                    I tried that it was working. Thank u very muchSmiley Happy
     If that LED is in a Cluster & i make that has indicator, everything present in that cluster changed to Indicator. I want to make only that LED as Indicator. How to overcome from this?
Thanks & Regards,
Harish. G.
Message 13 of 14
(590 Views)
Hi Ranjeeth_Singh,
      Thanks for ur help. That's not answer. Altenbach gave me solution. See that one!!
Thanks & Regards,
Harish G
Message 14 of 14
(580 Views)
