How to display 3 curves simultaneously on the same graph ?
Hi everybody, my problem is the display of curves from an array. I ve done a treatment for each wav file to get data (double) and save them as an array , so that every file got its proper array(one column).Each value corresponds to a methode.I would display all the curves on a graph to compare them later .So how can i have for 3 wav files 3 curves displayed on the same graph.Take a look to the image i uploaded to understand what is all about.
thanks.
(3,379 Views)
Hi sinaps,
switch on the context help, move the mouse over the graph's terminal and do as described in the help.
Or look at the examples regarding graphs and charts.
(3,376 Views)
Not sure if this is what you were asking for, but it's a quick little example.  It's an 8.6 file.
Tim Elsey
Certified LabVIEW Architect
(3,370 Views)
Im using Labview 8.5 version and im working on vista
(3,366 Views)
8.5
Tim Elsey
(3,354 Views)
sorry Timi was giving you the wrong version .Im using Labview 8.2
(3,350 Views)
(3,322 Views)
