How to display a HTML String in a ActiveX WebBrowser ?
How to direct display a HTML String in a ActiveX WebBrowser without use a URL ?
Message 1 of 8
(7,493 Views)
I am sure that it would depend on the browser, but with Internet Explorer from Microsoft, I don't think you can. (I may be wrong on this.) What you could do would be to save your string to file and read the file as a url in the browser. I know that this is a step you are trying to avoid, but it will work.
Hope that this helps,
Bob Young
Message 2 of 8
(7,493 Views)
Bob, you are wrong, it is possible...
Use the Navigate2 method, and in the URL don't wire a path, but a string,
like this:
about:
The "about:" is the key, after this you can put your html.
Wiebe.
"Bob Y." wrote in message
news:506500000005000000B0CF0100-1079395200000@exchange.ni.com...
> Bob Young
Message 3 of 8
(7,494 Views)
Wiebe,
This is really slick, but it seems there is a limit (1k or so) to the length of the html string.
Are there any tricks to inputing a bigger string?
Thank you,
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 4 of 8
(7,254 Views)
Anyone know an answer to this yet?  This came up in a google search for me and fits my problem exactly.
Message 5 of 8
(6,548 Views)
Are you stuck with ActiveX?
I suggest you simply use the .NET WebBrowser control and its DocumentText property to display an HTML string.
Message 6 of 8
(6,543 Views)
Nev mind- I found I can do this-
navigate2 "about: "
call doEvents
set document.body.innerHTML to my Html code.
I'm using microsoft access vba.  I didn't even know what language y'all were using  🙂
Message 7 of 8
(6,541 Views)
Like this.
Message 8 of 8
(6,534 Views)
