How to display a eyediagram?
To display a eyediagram in signals analysizer CSA803(Tektrnix inc.) I use
the NI driver directly (the Acqui & wav tk803 fuction). The Labview get the
waveform correctly, but the gragh indicator display the data with vector
mode other than dot mode, that means all the points are conncted by a line
one after another. so I can't observe the eyediagram. Is there any indicator
which can display the eyediagram correctly?
(2,760 Views)
Maybe you could just change the plot properties of the X,Y graph to just show
the points. You can change this attribute in the legend of the graph.
-Jim
"Xiaobo Hou" wrote:
>>To display a eyediagram in signals analysizer CSA803(Tektrnix inc.) I use>the
NI driver directly (the Acqui & wav tk803 fuction). The Labview get the>waveform
correctly, but the gragh indicator display the data with vector>mode other
than dot mode, that means all the points are conncted by a line>one after
another. so I can't observe the eyediagram. Is there any indicator>which
(2,760 Views)
