How to display a picture from an URL in NXG?
I am programming an interface for a spectrum analyser. This spectrum analyser comes with a web interfaces, that shows the display of the device. It can be accessed via http://10.117.12.135/Agilent.SA.WebInstrument/Screen.png
I would like to include and update this picture within my VI to see what's happening on the device.
I found this post and wanted to write something similar, i.e. download the picture and send it to an Image object. However, I can't find a way to change the picture by code.
Is this something that is not implemented in NXG yet? Any other ideas on how to solve this?
(2,822 Views)
Have you tried using the URL Image Control and its properties? https://www.ni.com/documentation/en/labview/4.0/class-ref/urlimage-class/
Rita Prather
Software Product Manager
rita.prather@ni.com
(2,706 Views)
Thanks for your reply! The class looks promising. Unfortunately, it is only available in web applications.
(2,700 Views)
Ah, right you are. While the URL Image Control isn't supported in the desktop case today, in LabVIEW NXG 5.0 (shipping in late May) we are introducing a Set Image method that will allow you to programmatically set the image path to an image object on the front panel.
Rita Prather
rita.prather@ni.com
(2,689 Views)
