How to display annotations comfortably on XY graph?
I have 2 plots(signal1 and signal2) on the XY Graph,they have the same X and different Y,like below picture.
I know how to add annotation for each plot, but my problem is that the annotation is not well displayed if the axis is not matching the plot data properly.
As far as I know,the annotation can be bind either to a point of a plot or to a position of the graph.
The thing is that the point of a plot may not be displayed in the plot area(black area) if the axis range are not as expected ,so that the annotation can not show up either.
The same as binding to a position of the graph.
Is there a smart automatic way to display the annotations in a viewable area on the graph?
(4,635 Views)
Hi avater,
use the plot legend to show the plot names - if this is the purpose of your annotations as shown in the image…
(4,615 Views)
Not really.
Actually I have more than 2 plots on the graph,but only 2 of them I would like to annotate to users.
Like plots on the graph are below:
Plot1:Signal1
Plot2:LimitsUpper1
Plot3:LimitsLower1
Plot4:Signal2
Plot5:LimitsUpper2
Plot6:LimitsLower2
So if I use plot legend,I cannot decide only Plot1 and Plot4 are displayed.
(4,608 Views)
Hi avater,
create your own plot legend: "array of cluster of (colorbox, string)"…
(4,602 Views)
How to create a plot legend of my own?
(4,595 Views)
HI avater,
as said before: by creating an "array of cluster of colorbox & string"!
Once you have the indicator arranged all you need to do is to read the plot properties and set colorbox and string accordingly…
(4,593 Views)
