How to display bad points in waveform-graph?
i have a waveform graph which displays three waveforms.
a.) a measurement-graph with 1000 points
b.) a upper-limit-graph with 1000 points
c.) a lower-limit-graph with 1000 points
Normally the measurement-graph is between the upper-limit-graph and the lower-limit-graph.
The normal color is yellow for the measurement and green for the limit-graphs.
What i want to do is to display the points which are beyond the limits in another color (red).
Is this possible?
Thx for your help
(2,583 Views)
Use NaN and multiple graphs. See the bar code example I posted to http://forums.ni.com/ni/board/message?board.id=170&thread.id=284478 a few minutes ago.
Lynn
(2,581 Views)
