How to: display large error note in the front panel?
hi guys,
When "error out" has an error, I would like to display HUGE RED TEXT in the FRONT PANEL saying: "STOP, ERROR DETECTED!"  :))
How to do that?
Thanks for your help.
(2,399 Views)
Accepted by topic author testas123
Place an indicator on the panel. Set the text to HUGE and RED, and set its value to "STOP, ERROR DETECTED!". Make it not visible. When you get an error, use the "Visible" property node to display it.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(2,395 Views)
