How to display number of samples received.
So want to display how many samples I have read. I have seen in some discussions that i should use "DAQmx read property node" but where exactly should i place it in my VI. Also I want to stop my code after acquiring exactly 675 samples. How should i do it? Attached is my receiver vi.
(2,531 Views)
Accepted by topic author maverikk
Hi maverikk,
Remove the loop from your VI.
Then change "number of samples per channel" to a constant and set its value to 675.
Finished.
Why do you need a property node to know the number of samples read?
Just use ArraySize on your Y array in the waveform…
Why do you need this at all? When you set DAQmxRead to read 675 samples and it returns without error then you got exactly 675 samples…
(2,524 Views)
