How to display ohm sign in string indicator.
Well that was strange. I know I copied the text from the address bar. Must have accidentally changed tabs in the browser without realizing it.
Darren's nugget: http://forums.ni.com/ni/board/message?board.id=170&message.id=222263.
Message Edited by smercurio_fc on 09-04-2009 09:46 AM
Message 21 of 29
(3,990 Views)
Ben,
you answered to that nugget more than 2 years ago 😉
Greetings from Germany
Henrik
LV since v3.1
Message 22 of 29
(3,928 Views)
thanks for the link..
Message 23 of 29
(3,923 Views)
sebster wrote:
The original question was 'How to display ohm sign in string indicator'
This solution is for a numeric indicator.
vijtin - which do you require?
Vitjin, you need to respond fast.
Or, is this has solved your problem, please mark it as the correct solution.
- Partha ( CLD until Oct 2027 🙂 )
Message 24 of 29
(3,911 Views)
Henrik Volkers wrote:
Ben,
Yes and I went back to that Nugget and still did not see where the Omega was mentioned or alluded too. Good news is this time it got through and maybe it will stick.
Ben
Message 25 of 29
(3,886 Views)
Any specific reason?
Message 26 of 29
(3,882 Views)
IMO, poster must be the fastest responder than the answerers. Smiley Wink
Message 27 of 29
(3,865 Views)
I want to display ohm sign in many indicators so i have tried that property node coding for one string control and then connected local variable of that string control to other indicators but it didnt work in other indicator it is displaying w only so can you tell me how to do that?
Vijtin
Message 28 of 29
(3,814 Views)
You need to use the same property for all the other indicators also, to take effect. Smiley Happy
Message 29 of 29
(3,804 Views)
